DISASTER!! urgent advice needed
Discussion in 'General TV Discussions Forum' started by candleman, Sep 23, 2004.
  1. candleman
    candleman
    Oct 21, 2003
    42
    oxford
    Can't believe i've done it but........ the missus put a speaker on top of my 32 tosh picture frame, I forgot about the damage they can do, it's been on there for a few weeks and yes the corner has some very odd colours now.
    Has anyone got advice about this? can it be put right? even kind words at this stage would be good i'm gutted :(
    cheers all
    dave
  2. red16v
    red16v
    Aug 20, 2004
    552
    +5
    Sounds like you've magnetised the shadowmask. The tv will automatically degauss (de-magnetise) the faceplate of teh CRt evretime you switch it on (from cold) so with any luck the effect MAY disappear over time. Other than that you will have to get the faceplate de-magnetised with a external degaussing tool - I doubt you have one of these at home so you may have to borrow one form a friendly local TV shop or at worst get an engineer out to do it for you - that would be a pity since it only takes 10 seconds flat. regards, yt
  3. brummybloke
    brummybloke
    Jul 18, 2004
    91
    i had this with my old jvc the speakers were magnetic and not at all like new speakers for 5.1.
    it took a week but the green which had come in the corner of the screen eventually went.
    most new speakers built for home cinema and non magntic field now.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Get a hair dryer face it away from TV and put the back to screen see if it works. then turn TV off will hair dryer is still going.
  5. candleman
    candleman
    Oct 21, 2003
    42
    oxford
    the hairdryer thing works!!!!!!!!! thank you so much
  6. mepsipax
    mepsipax
    Mar 20, 2004
    181
    +8
    Can this happen with 5.1 centre speakers on top of TV - i.e Mordaunt Short 304?
  7. funkmonkey
    funkmonkey
    Sep 5, 2004
    107
    16
    Sheffield
    Never knew about that handy tip, cheers :smashin:
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Actually any AC motor will do it (its the moving magnetic feild that does the trick (just dont to it too often if it needs doing too often get the set looked at pronto!
  9. Laurel&Hardy
    Laurel&Hardy
    Only if it's not magnetically shielded. If the speaker specifies it is then you can place it directly on top of or below a TV set.
    My mate with Isobariks has a terrible time because the magnets on those KEF B139B bass units are very, very powerful. The TV has to be at least a foot away from each speaker, otherwise it affects the purity!
