Disappearing picture on 32PW9527
Discussion in 'General TV Discussions Forum' started by Gordon A, Aug 28, 2006.
  1. Gordon A
    Gordon A
    Mar 23, 2002
    145
    +37
    Anyone shed any light on this? Got a 3-year-old Philips 32PW9527 that's just started exhibiting strange symptoms: every now and again the picture disappears and an associated static-like 'pop' is heard! It's not loud like a lightning crack but it's there all the same. Sometimes, too, when the picture has gone, there's a brief R, G & B display in the centre of the screen. All this lasts approximately half a second and then all's back to normal.
  2. sheldonstv
    sheldonstv
    it wants to be looked at quickly as you may have soldered joint troubles in the line stage,lopt with a pinhole in its casing,flyback tuning cap early failure or not soldered to the pcb correctly or a problem with the scan coil connector......
