Disabling Sound from TV
Discussion in 'AV Receivers & Amplifiers' started by ibrady, Aug 14, 2002.
  1. ibrady
    ibrady
    Need some more help ...........
    I have connected the audio out ports on the TV (PAN TX-32PL30D) to my receiver (DENON 3208), however I still get sound from the TV speakers.
    Is it possible to somehow disable the TV speakers and only use external ones - that is appart from simply pressing mute on the TV ?
  2. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    23,706
    2
    In a secret location with Jennifer Lawrence
    +10,693
    Why don't you just turn the volume right down?
    Thats what I do on my TV. Not sure what other way there is of doing it.
    Greg
  3. ibrady
    ibrady
    Your right it works - however if you go close to the TV you can still hear the static from the TV speakers.
    I guess if there is no solution I will just have to live with it.
    Thanks,
    Ian
  4. mjn
    mjn
    May 24, 2001
    23,182
    Herts, England
    +11,400
    open the Tv up, and snip the wires to the internal speakers?
  5. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,565
    Somewhere in South Yorkshire
    +6,083
    If the TV has a headphone socket on it, buy a plug to fit the socket and stick it in. This will probably mute the speakers.
  6. Jase
    Jase
    Mar 16, 2001
    10,721
    United Kingdom
    +2,487
    Does the TV have an option to switch the speakers off?? My JVC has it in the Audio menu, you then have to use the volume to raise the output of the analogue outs.
