disabling sony bravia osd
Discussion in 'Sony TVs Forum' started by neilcoates1234, Feb 17, 2014.
  1. neilcoates1234
    neilcoates1234
    Feb 17, 2014
    I have a Sony kdl-40w5710 which i am generally very pleased with. I have just bought an onkyo soundbase to improve the sound which it has.
    However when adjusting the volume, i am frustrated by the osd telling me that the speaker is the audio system and that the tv volume is fixed - a message that stays on the screen for 5 seconds.Is there a way to either disable the osd or reduce the time it is on??
    I cannot find any menu setting to do this.
  2. JayCee
    JayCee
    Jan 20, 2004
    23,764
    Lanarkshire
    +2,572
    With what?...the Tv or Onkyo remote?
  3. neilcoates
    neilcoates
    Apr 27, 2008
    2
    Using the Sky remote(which we use for all TV function).The Onkyo remote does not make the Tv osd come on , but I dont want to have 2 remotes in use.
  4. toadz
    toadz
    Jan 22, 2014
    393
    46
    Manchester
    +165
    If you had a soundbar with HDMI then you could probably have used the arc channel (HDMI 1) to avoid having to use two remotes. As it is I think you are stuck with using two.
  5. ham_mcfist
    ham_mcfist
    Nov 5, 2008
    60
    Stockport
    +5
    You keep seeing the OSD message because A- the TV is set to use external speakers and B - the Sky remote is still sending volume commands to the TV, instead of the soundbase.
    Program your Sky remote to control a Sound System - Sky Community
    I can't guarantee the above guide will work but it does appear to have Onkyo remote codes on the list. Make sure you follow the whole guide and enable the volume/mute override - this will save you having to flick between "Sky" and "TV" every time you want to control the volume of the soundbase.
