Disabling RCE and Macrovision
Discussion in 'Blu-ray & DVD Players & Recorders' started by VINNY, Jul 26, 2001.
  1. VINNY
    VINNY
    I have a Tosh 2109B Multiregion DVD player. Does anyone know where I can obtain cheapo boxes\cables etc that will disable RCE and\or Macrovision.
    Thanks in advance
  2. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Macrovisions fairly easy, just try keene or lektropaks, they usually have cheap image stabilisers.
    RCE will probably need a chip on a Toshiba, try techtronics.
    I haven't got the handy but if you want the web sites I can dig them out.
    Hope this helped
    Slingshot
  3. VINNY
    VINNY
    Thanks m8, I also have this info and will give it a shot first.
    1. Wait for blue screen (MGM)/world map (Columbia-Tristar) to appear
    2. Press 'memory' on the remote
    3. Enter 0 1 for title
    4. Press 'play' and then 'clear'
  4. bob007
    bob007
