Disabling PSM removes colours
Discussion in 'TAG McLaren Audio Owners' Forum' started by edward, Sep 24, 2005.
  1. edward
    edward
    Apr 2, 2003
    855
    32
    Reading
    +26
    Argh!! What have I done? I turned off PSM in my processor and the colours immediately disappear. I enabled PSM months and now I can’t remember what I had to do that preserved the colour.
    It’s probably very simple but what is it?
    (yes, I did do the RTFM bit).
  2. Joelc
    Joelc
    May 16, 2004
    414
    +5
    You need to check the PSM output format...not knowing your kit and subsequent connection you likely have, as you note, an "output" mismatch.
    Hope this helps.
    Joel
  3. edward
    edward
    Apr 2, 2003
    855
    32
    Reading
    +26
    Thanks Joel,
    Haven't seen you for a while - trust all is well.
    Assembled throng start arriving about 15 mins from now so I'll tinker, probably fruitlessly, once more in an area of the menu system I've not explored for a while.
  4. Joelc
    Joelc
    May 16, 2004
    414
    +5
    Edward:
    Let us know how you get on...i will be able to assist you in an hour or so should you still require it.
    As far as busy is concerened -- very swamped with work which translates to little home cinema :mad: :thumbsdow :(
