Disabling MJ sub crossover?
Discussion in 'Subwoofers' started by SeeNoWeevil, Oct 18, 2003.
  1. SeeNoWeevil
    SeeNoWeevil
    Oct 14, 2003
    2,690
    +873
    I was told by MJA that turning the pro50 x-over to the maximum 270Hz(?) disables the x-over.
    I've always had it like this but when measuring with an spl meter I noticed considerable output above the amps crossover??
    X-over was set to 80Hz and there was loads of output on the 160Hz+ tone?
    At the moment I have it cascading with the sub set to 80 or 100Hz as well as the amp.
    Any ideas
  2. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    Do you have a high level connection as well as low level?
  3. SeeNoWeevil
    SeeNoWeevil
    Oct 14, 2003
    2,690
    +873
    no just low level, i dont see the point in having a high level connection?
  4. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    High level's useful if you have an integrated amp taking care of hi-fi duties, it does interfere with movies though (so hi level gain turned right down for movies)
    What amp do you have? does it have a specific crossover or can you set it?
  5. SeeNoWeevil
    SeeNoWeevil
    Oct 14, 2003
    2,690
    +873
    its a Denon 2802 with 80/100/120Hz.
    I think I really need to disconnect the main speakers and test the sub above the x-over. Dont think there is an easy way to turn off the mains without disconnecting the binding posts.
