disabling macrovision
Discussion in 'Blu-ray & DVD Players & Recorders' started by puc, Jul 23, 2002.
  1. puc
    puc
    Jun 17, 2002
    167
    +4
    I've recently bought a Tosh sd110e from Richer sounds (£99 -great value). It came labelled as "multiregion" so i guess it'll play any region disk.
    However, it still has macrovision enabled. I was trying to make a backup copy of a disk in order to establish this without success. I even tried a JVC video enhancement unit but this gave me a poor image on the monitor and only sound on the recorded tape.
    I dont want to further modify my player so can anyone advise on a good method to bypass macrovision, purely for backup purposes?
  2. Guest
  3. Samantha
    Samantha
    Mar 10, 2002
    356
    Do they work?
  4. z5461313
    z5461313
    Sep 18, 2001
    1,661
    +241
    Are there any products that do it for component output?
  5. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,527
    Somewhere in South Yorkshire
    +6,000
    You should be aware that you won't be able to "back up" to tape any DVD that is in the NTSC format - eg R1 and Japanese R2 items without a standards converter or a multistandard VCR. The signal produced by your player, when playing an NTSC disc, is incompatible with all regular VCRs.
    The usual symtoms of trying to record a PAL (eg R2, R4) item with macrovision ON is a picture which fluctuates hugely in brightness, varying from normal/watchable to extremely dark and possibly unstable. "No picture" is not the usual consequence of macrovision.
