Disabling auto aspect via scart
dUnKle
Joined
Jan 1, 2001
Messages
18,968
Reaction score
6,041
Points
4,542
Have my Sky+ box connected to TV via SCART
All was well with just the annoyance of the TV changing the aspect of the picture all the time - it may shock many but I prefer (at the expense of fat faces) to use the whole TV screen
Anyway - took an old Scart cable and disabled PIN 8 - it works - however I have also lost RGB and even though I have told the Sky+ box to output RGB the picture on the TV is as if it was off :(
Can this be corrected - or am I stuck with auto aspect ?
This feature is controlled by the tv not the shy box all you need to do is switch your tv off the auto mode.
I think you have just killed the scart cable. :eek:
Tv does not have the ability (as far as I can tell) to disable auto switching
Was told pin 8 did it - but looks like I was 4 days late for April Fool
Pin 8 is right. And it should have NO effect on RGB at all. Cutting pin 8 will prevent the TV from automatically switching to this AV input as well as killing the widescreen switching. You may perhaps be looking at an RF feed from the Sky box. You may need to select AV1 or whatever manually on the TV.
Cheers for that - not sure what I am doing wrong then
I have a Sky+ box which is connected to a DTL-532W100 LCD Set
Its connected via Scart only (TV has no RF feeds or anything going into it) and the scart was going into Scart 1 (the RGB Scart) on the TV
Having been advised on here about pin 8 and reading few more links I pulled out Pin 8 from both ends of the scart cable
Upon replacing the cable, the auto aspect switching has indeed gone, but so to has RGB and the picture is the same as what I would have got if I had set the SKy+ box to non-RGB mode
All most strange
Is pin 8 always in the same place on all cables ? And I assume it would be the one with the little 8 next to it. I have attached a pic of the pin I pulled out - as you look at the pic - its the fourth pin from the left on the top row
Anyone know what I am doing wrong ?
4th from the left on the top row is correct for all SCARTs. Have you by chance damaged/severed any of 7, 11 or 15 while you were attacking pin 8?
Nope - certainly not that I can tell - just used pair long nose pliars and twisted the pin til it came off - did both ends as well
Open the Scart plugs and make sure you have not caused a short when you were twisting the pins. The right way to remove the connection would have been to open the plug and snip the wire off pin-8 close to the pin.
Ken
Ken
Cheers - went and got another scart cable - tried again
Works in RGB mode before surgery
Opened cable up
Snipped wire 8 - coverered wire with tape to make sure no touches
Plugged back in
Same happens - auto switching goes - but the TV no longer accepts RGB :(
StormAudio ISR Fusion 20 AV Receiver - review coming soon #HomeCinema #Amplifier #VideoShort
Back
