Disable HDD on SKY HD box
mo786
Established Member
I do not record on my HD box
Can I open the box up and literally disconnect the HDD so it shut the up?
logiciel
Yes, but sooner you than me to get into it.
mo786
Established Member
prsumably if the Software cannot find a HDD it wont stop working?
i'll have a try getting into it a bit later!
chic
you need the hard drive to cache the 7 day epg, no hard drive then no epg.
mo786
Established Member
frustrating
Above poster must be right as it wouldnt come on when i disconencted the HDD
It did carry on working if I turned the HDD off after it had booted.
I will look into finding a quieter HDD as the difference when it is off is massive. i also saw a thread where someone sued an SD card type HDD which would be ideal.
logiciel
You got into it OK then?
Those solid state drives are a bit pricey so I'd try using a standard one.
mo786
Established Member
Yea I found athread which showed how to open the box, it was a case of
6 screws out from the underside
pop off the silver bits on the sides
couple more screws and off pops the top black bit
then 3 more screws on a metel lid under the outer black lid
HDD has a Sata cable, a fan cable and then one more pwoer cable.
CES 2023 Round Up: New TV Lineups for 2023 from LG, Samsung, Panasonic, Hisense & TCL
