Disable dvdpsm
Discussion in 'TAG McLaren Audio Owners' Forum' started by johnson, Jun 21, 2005.
  1. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    If I have a psm in the av192 and dvd32r, how do I disable the one in the dvd?
    Anyone help?
    Thankyou
  2. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    You can't as it's physically wired to the BNC outputs of the player. Use the phono outs to get the pre-PSM interlaced feed.
  3. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    Thanks Steve.
    So, If I still want to use the BNC's (for better quality) can I feed the progressive from the dvd through the 192?
    Sould I change settings in the 192? I have sky also being de-interlaced by the 192 and it's easy having that switch everything for me.
    Regards
    Simon
  4. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    You can but you will then loose AV192R OSD as it can only overlay on an interlaced signal and overall operation isn't as smooth as using only the PSM in the AV192R.
    There is virtually zilch difference between using the phonos and the BNC's on an SD interlaced signal if you use proper video phono plugs that have a 75ohmish impedence (like the Canares). On my system at home I run phono out of the DVD32R and feed it into RGB1 on the AV192R.
  5. hoosterw
    hoosterw
    Dec 14, 2004
    16
    in NL near Eindhoven
    Hi Simon,
    Maybe if it makes you more comfortable, I run my system as Steve.
    DVD-RCA output interlaced to BNC RGB AV192 input using a NordOst Silverscreen cable.
    Superb picture!
    Rgds Hans
  6. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    Thanks guys,
    Can you clarify this for me?
    I have the dvd32r output via BNC (Nordost) to RGB1 (BNC) input of Av192.
    I have just played a dvd and it works!!
    I take it the dvd is outputting Progressive, so what's the av doing with it?
    To clear things up my end, My dvd32r without psm stopped working yesterday, that's why I'm using this one.
    I've just connected it the way my other one was.
    In the av192 menu I still have "üse av192 PSM" enabled.
    I would rather use the PSM in the av but my Nordost was 500 pounds and I'd rather not change it if it's working
    Am I currently doing anything wrong? because the way I read this is it shouldn't be working, progressive out to input of de-interlacer !?!?
    Best regards
  7. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    I didn't say it wouldn't work, you just loose various functionallity. The AV192R will detect the progressive scan signal and will route it directly through to the outputs rather than feed it into the internal PSM.
  8. hoosterw
    hoosterw
    Dec 14, 2004
    16
    Yeah it works either way, but like Steve said you can't have AV OSD.
    Maybe try some good RCA-BNC adapters to get the BNC of the cable connected to the RCA outputs of the DVD32. (I used some until I got the right cable).
    I assume you have no scaler in the AV192?
    Rgds Hans
  9. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    Ahh,
    Thankyou. Both. Appologies .
    O.K I'm going to lose av osd when playing dvd,s?
    I had the dvd menu displayed earlier, then pressed menu for the av and that was then displayed.
    I'm just glad it's working and I'm not doing anything to harm it.
    Just wainting to see what's up with my other 32r!! (only 3 years old, had it from new.Still looks new!!)
    Hans, no My 192 has everything bar the scaler :(
    Many thanks
    Best regards
  10. hoosterw
    hoosterw
    Dec 14, 2004
    16
    Ah Simon,
    Maybe a little clarification, yes the menu etc will be displayed, but the AV can also have On Screen Display of text when watching (e.g. volume adjust etc as you see it on the AV display) This is now for you not possible.
    That is what is meant by loosing OSD possibility.
    Sorry for the confusion.
    Lucky me, I do have the scaler!!>!>!>:):) :D :rotfl: :hiya: :clap:
    Hans
  11. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    Thankyou Hans
    Appreciated
    Simon
