Disable DVD32R auto play?
Discussion in 'TAG McLaren Audio Owners' Forum' started by memmerson, Jul 20, 2005.
  1. memmerson
    memmerson
    Dec 12, 2002
    466
    Devon
    +16
    Hi guys,
    each time I bring my Tag gear out of standby my DVD32R starts playing the DVD (if inserted).
    Is there a way I can stop this behaviour? I'm sure there should be an option for this somewhere but I just can't find it!!!
  2. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    Nope.....
  3. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    Actually you can stop the DVD player waking up at all just go to the TAG bus settings and sort it, but the DVD player once woke will scan what is in the player and start playing it if it is a DVD (not all DVD's though so I assume it has more to do with the encoding of DVD's than the player per se).
  4. memmerson
    memmerson
    Dec 12, 2002
    466
    Devon
    +16
    Cheers Graham, unfortunately for me I require the DVD32R to be on as I am using the PSM module to deinterlace my sky signal.
    Oh well, guess the missus will just have to learn how to deal with it!!
