disabeling antivirus = faster video conversion??
Discussion in 'Computer Software & Operating Systems' started by stonfiesta5, Sep 19, 2007.
  1. stonfiesta5
    stonfiesta5
    Jun 12, 2007
    122
    So as titled really, if i turn off all my norton antivirus stuff will converting video clips become noticeably faster?
    Hope someone can help. Ive searched but with no luck.:smashin:
  2. hottstuff
    hottstuff
    Dec 20, 2005
    3,617
    Rep. of Ireland
    +149
    If you turn off Norton Antivirus almost everything on your pc will run faster.:D
    Norton AV is a notorious system resource hogger and i would disable everything to do with it especially when converting video files etc.
    In fact i would completely uninstall it , if you have a back up of course.;)
  3. stonfiesta5
    stonfiesta5
    Jun 12, 2007
    122
    cheers:smashin:
    looks like i'll just turn it off when converting......unless you can recommend something better? :lease:
  4. hottstuff
    hottstuff
    Dec 20, 2005
    3,617
    Rep. of Ireland
    +149
  5. doublej
    doublej
    Jul 3, 2005
    122
    +13
  6. Decadent Fool
    Decadent Fool
    Dec 27, 2006
    546
    28
    Shropshire
    +33
    Have a look back a couple of pages or so, there was a good thread on here about AV and firewalls :)
  7. hottstuff
    hottstuff
    Dec 20, 2005
    3,617
    Rep. of Ireland
    +149
    Subjective to opinions.
    Never had any issues myself in the last 8 years and i have never used Norton.
  8. Steve.J.Davies
    Steve.J.Davies
    Nov 14, 2004
    2,995
    83
    +199
    do you 'need' it to be faster ?
    if you need it as fast as poss consider creating a separate cut down windaz partition with NO net access and invisible from the main windaz setup (via Bootmagic or somesuch). then you can tweak the video partition to go as quickly as windaz can.
    you on XP or Vista. if on Vista then use XP.
    better yet put a linux partition on :)
  9. MarkE19
    MarkE19
    Aug 10, 2002
    17,544
    Rainham Essex
    +2,523
    If on XP then do a search for a free downloadable program called EndItAll2 - it does exactly as the name suggests and stops all the unrequired background programs. But be aware that you should disconnect from the internet/network first to avoid and problems with attack as antivirus/firewall software will be stopped leaving the PC unprotected. Just reboot the PC to get everything running again.
    If you can't find EndItAll2 then PM me your e-mail address and I'll send you a copy.
    Mark.
  10. Buff99
    Buff99
    Aug 23, 2005
    55
    Edinburgh
    +10
    why not just exclude from your virus scanner the video filetypes you are working upon?
  11. hottstuff
    hottstuff
    Dec 20, 2005
    3,617
    Rep. of Ireland
    +149
    It's not the virus scanning itself that can cause issues for average PC's being maxed out with video conversion etc, its the valuable resources that programs like Norton can Hog on you.
  12. treacle
    treacle
    May 17, 2006
    598
    +16
    Take no notice of the Anti-Norton gang, any AV will slow your system down, its just another chance for their senseless rant.
  13. hottstuff
    hottstuff
    Dec 20, 2005
    3,617
    Rep. of Ireland
    +149
    :rolleyes:
  14. Member 55145
    Member 55145
    Jan 18, 2005
    12,082
    +3,483
    its true, any AV program will take up resources, but only norton knows how to hog it :thumbsup:
  15. treacle
    treacle
    May 17, 2006
    598
    +16
    Don't talk stupid.
  16. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    Yet again someone dares to have a differing opinon to your own so the insults start to fly. Tread carefully Treacle
  17. Member 55145
    Member 55145
    Jan 18, 2005
    12,082
    +3,483
    i fail to see how thats stupid, have you even worked with a computer? i've worked around computers for a very long time and can categorically say that its the slowest, untidiest useless AV suite i have ever had the misfortune to use.
    care to give reasons for your clearly opposite viewpoint
  18. Uridium
    Uridium
    Jan 29, 2005
    14,434
    +1,855
    Same here. I've been deploying AV suites for years and have never come across any AV software as bloated and cumbersome as the Norton home products (Mcafee comes a close 2nd mind)
    It's a shame as the Symantec corporate AV products are superb.
  19. treacle
    treacle
    May 17, 2006
    598
    +16
    Here it comes, "I'm an expert " "You don't know anything"
    I know my way round a computer, I've no need to blow my own trumpet like yourselves,
    All the adverse criticism is only your opinion, and I think you're talking out of your backside.
    I bet you've not even tried the latest 360 application, all you so-called experts are living in the past, dwelling on earlier Norton products which did have flaws, only the AV program was any good.
  20. Singh400
    Singh400
    Feb 21, 2006
    17,850
    Earth
    +3,370
    I have, and I still declare it bloatware.
    Agreed, they should rework SAVCE into the home edition. SAVCE is great.
  21. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    do you have to resort to belittling people to get a point across, if you can't post a civil reply in this thread than don't.
    Curly
