dirty heads?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by graham.myers, Jul 1, 2002.
  1. graham.myers
    graham.myers
    Its holiday time again so I dusted down my trusty (!) pc100 dv camcorder and bought a couple of new tapes (sony).
    I always lay down an initial time code on the entire tape before I use them so there is a consistent time code when I come to editing on my PC.
    Anyway I left it recording a blnak scree nand when I came back it didn't seem to have laid down a time code. Or picture.
    So I record with the cam pointing out the window. nothing.
    i put an old used tape into the machine. It plays for about a second and then pixelates and then freezes. The tapes does not look crumpled.
    I am assuming this is clogged heads although they look fine.
    can I clean these myself or do I have to send them off?
