DirectTV Tivo receicer any good without satalite?
Discussion in 'Digital TV & Video Players & Recorders' started by stuntroc, May 19, 2003.
Tags:
  1. stuntroc
    stuntroc
    If I get the satalite receiver with Tivo built in, can I use it without satalite? I'm not sure if I will stay with satalite long term, and I don't want to have to purchace another Tivo unit if I switch back to cable.
    Does anyone know if the DirectTV Tivo unit has the ability to change channels on a cable converter?
    Any opinions on my options?
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    You'll probably be better off asking in a US based forum such as http://www.avsforum.com we are UK based and as such most models etc. discussed apply to PAL areas ;)
  3. stuntroc
    stuntroc
    Thank you.
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    IIRC the DirectTV TiVo has no way of inputting an external video source, therefore if not useing satalite its a new TiVo.
    Mark.
  5. stuntroc
    stuntroc
    Good to know, thanks.
