Directly viewed whites become yellow even at max color temp.
Discussion in 'OLED TVs Forum' started by GuardianGI, Dec 8, 2017.
  1. GuardianGI
    GuardianGI
    Sep 27, 2017
    11
    Estonia
    Got a c7v and it seems I have to view the tv at 35-85 degrees or else suffer discoloring and yellow whites. Off-angle the tv looks awesome and corresponds to the color temp(cool and blue), but when directly viewed it gets a yellow tinge. It seems to have the reverse problem of VA panels. Is this normal for OLEDs or do I have a defective screen coating or something?
  2. steviedr
    steviedr
    May 23, 2006
    5,842
    +3,889
    There’s a tint thread within the oled thread.
    It annoying, some have it some don’t.
  3. lapino
    lapino
    Jan 17, 2005
    1,474
    48
    Oudenaarde
    +57
    2017 Oled Yellow/Red Tint . Long thread, my 65" has this too. Seems the 55" is less prone to this, but as far as I know all 65" OLEDs suffer from this.
  4. Paul D
    Paul D
    Dec 27, 2000
    2,797
    Manchester
    +558
    This is colour shift, and not the yellow red tint in that thread. The shift is caused by the polarising filter to reject ambient light.
    You are not seeing yellow whites as such rather the correct image when dead on centre. You then get a blue tint when off centre.
    If you adjust your white balance, you can change those yellow whites to be more blue. However, off centre your whites will be even blue-r if you see what i mean.
    It's funny how nobody other than AV Forums Phil Hinton has mentioned this trait...
  5. lapino
    lapino
    Jan 17, 2005
    1,474
    48
    Oudenaarde
    +57
    Yeah well, could be colour shift. In fact I'm pretty sure the difference in colour tone I see is due to the AR filter...BUT...problem is, the shift is there when I sit directly in the middle of the tv. When I move (pretty far) to the left, the left becomes clear and has the correct colour balance, but then the right gets a bit worse. Same other way around. When I sit right in the middle, the left has a clear colour shift, the right too but little less pronounced.
  6. GuardianGI
    GuardianGI
    Sep 27, 2017
    11
    Estonia
    Can you link me the discussion where Phil Hinton mentions this color shift issue? Could getting a different unit fix this issue? It seems the color shift affects whites the most and shouldn't bother me when watching movies or playing games (unless when there's lots of snow), but web browsing is very bothersome (sites with loads of whites like avforums and reddit). It's really bad when a 400€ budget 4k tv can display white websites better.
  7. ryanvincent
    ryanvincent
    Jul 26, 2017
    464
    46
    Stoke/London
    +176
    Many OLED's do have this issue if it bothers you a lot get a exchange.
    It can also be reduced by getting your set calibrated.
  8. GuardianGI
    GuardianGI
    Sep 27, 2017
    11
    Estonia
    I can't believe rtings.com rates this as "the best tv" for pc monitor usage. Even at 100% brightness the OLED gets decent brightness at best, not to mention you constantly have to fight with the ABL and ASBL (dimming every 60 seconds) when web browsing.
  9. GuardianGI
    GuardianGI
    Sep 27, 2017
    11
    Estonia
    Found this video on youtube:
    LG 65C7 color shift
    Ignoring the staining that OLED has on the left side (srsly I hope he returned it), I seem to have the opposite effect seen on this video, instead of whites becoming yellow off-angle my oled has yellow whites when directly viewed (even with maxed temp) and proper bluish whites off-angle. It seems there seems to be balancing act in the manufacturing process.
    I am going to check some of the floor models if or how badly they have this color shift issue (and which way the color shifts).
  10. lapino
    lapino
    Jan 17, 2005
    1,474
    48
    Oudenaarde
    +57
    This is my video. What the video maybe doesn't show, is mine is the same. I get yellow whites when viewed directly too, mainly to the left side. The yellowing shifts when going off-axis, but when I sit perfectly in the middle, it's yellow for 10% on the left, 50% ok, then 40% yellow on the right (less so than on the left).
  11. steviedr
    steviedr
    May 23, 2006
    5,842
    +3,889
    Yep, I have had similar experiences although my last was pink.
    Never had a good one, very jealous of those who have.
  12. GuardianGI
    GuardianGI
    Sep 27, 2017
    11
    Estonia
    Your model has the red/yellow stain issue, which is a separate issue, but it does produces the same problems (off-color whites). My oled doesn't have red/yellow stains but instead has a effed up color shift.
  13. lapino
    lapino
    Jan 17, 2005
    1,474
    48
    Oudenaarde
    +57
    Strange thing is, when filming/photographing this, it appears reddish. But irl it does look more like yellow. Very hard to photography when viewing directly, in fact pictures look fine but irl it is definitely there.
  14. GuardianGI
    GuardianGI
    Sep 27, 2017
    11
    Estonia
    Ok, I managed to check all 4 OLED models in the store, specifically the sony a1e, c7v, b7v and e6v, and they all had the same yellow colorshift when directly viewing white content. I am going to check another store.
  15. steviedr
    steviedr
    May 23, 2006
    5,842
    +3,889
    My last one had 2 yellow stained areas straight on, but if you moved up to 70 degrees the yellows would change from yellow to white to blueish white.
    I sat on the left side and I’d see yellowish white on the left side my wife on the right side wouldn’t see it as much.
