Directionality on analogue interconnects......
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Sunday Ironfoot, Apr 24, 2003.
  1. Sunday Ironfoot
    Sunday Ironfoot
    ...should the arrows printed on the cable point in the direction of the CD player or the amplifier? What difference does it make to the sound?
  2. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    The direction of the arrows run from the CD Player ------> Amp.
    There is only a difference in sound if you can hear one (very unlikely). However some cables are designed to be grounded at one end only so wherever a cable specifies direction, you should adhere to it :).
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,011
    +2,808
    At risk of getting flamed....
    CHeck direction by listening. Not all cables are marked correctly. Who knows, you might not hear a difference and it'll all be irrelevant. Only takes 2 minutes to do though.
    Gordon
  4. UselessPratt
    UselessPratt
    Some cables do sound different depending which way they are "facing" and Gordon is right, sometimes they are not marked correctly and or folks prefer them the wrong way round.
