Direct TV Standard Definition Is Worse Than Cable
Discussion in 'Satellite TV, Sky TV & FreeSat' started by petersinh, May 4, 2003.
  1. petersinh
    petersinh
    I just had Direct TV installed this week to a HDTV and a standard NTSC TV. The video quality displayed on the standard NTSC TV is softer and grainier than our Comcast cable. The color rendition is also "colder" and less rich (people skins are more pale, for example). Is this inherent in Direct TV, or is it the low video quality of the set top box (a $75 Sony STB, sorry I'll get the model number in the next post)?
    My advanced thanks to your feedback.
    Regards,
    Peter
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    You might want to try the AVS Forums, you'll find far more info and feedback on those since they are mainly US based:)
  3. WyrTwister
    WyrTwister
    I get a great picture on all my DTV receivers & can tell no difference between brands .
    Wyr
