Direct sunlight on the back of plasmas
Discussion in 'Plasma TVs Forum' started by kace, May 25, 2004.
  1. kace
    kace
    My TV is situated infront of patio doors. The back faces the windows and occasional direct sunlight. Will this in anyway damage the unit?
    Opinions?
  2. Elvis
    Elvis
    Could it contribute to overheating if you're watching TV on a hot, sunny day?
  3. hammerman
    hammerman
    I cannot believe for 1 second that direct sunlight on any electrical item (other than a solar panel,lol) would be anything but bad news..........
  4. Elvis
    Elvis
    I guess it depends what you mean by direct sunlight. My plasma is in the sitting room close to a large bay window. During the summer daylight streams in through the window and onto the TV. The only way I could avoid this is by closing the blinds during the day, which would look a bit odd. I'm not concerned about this level of daylight on my plasma screen and I suspect Kace needn't be either.
  5. hammerman
    hammerman
    I'm sure if you read the instructions........whatever screen you have........ it will tell you to avoid locating in direct sunlight.......... ;)
  6. Elvis
    Elvis
    That's the kind of thing manufacturers say to cover their backs. I don't think it's really going to cause a problem. Only some really obsessed nut would close their blinds everday to stop their precious TV being harmed by sunlight.
    What about other elctrical goods? We'd have to keep the kitchen, bedrooms, study etc in the dark to protect all the electrical goods in there as well! :eek:
