I have a Panasonic DMR-BWT800 which has a SCART connection to my Sky+HD box so that I can copy (albeit in analogue) recordings to acrchive to BluRay. I do also have a DMR-BWT850 that does not have the SCART input.
I have tried using a Triax DVB-T modulator to modulate the output of the Sky box and then record the assocaited TV channel that Triax outputs.
Unfortunately neither Panasonic will record. When I use direct record set to continuous - ie until I manually stop it the red REC light comes on on the Panasonic unit, but the counter stays at 00:00:00 and no recording is made.
I wondered if anyone else had successfully recorded a locally modulated signal in this way ont he Panasonic recorders?
The output of the Triax modulator works fine for display on the Panasonic, which correctly identifies it as a 1080i source, or indeed 1080/24p if used with a blu ray player.
