Direct DVD - Please help!!
Discussion in 'Desktop & Laptop Computers Forum' started by benji_m, May 8, 2002.
  1. benji_m
    benji_m
    Apr 14, 2002
    708
    Lancashire
    +6
    I have Direct DVD 4.03ES running on a Athlon 1800XP with 256DDR Ram and Win XP Pro. I currently am running a Sis 8mb video card while my gf2 is being repaired under warranty - I cannot get a smooth dvd playback no matter what resolution of colour depth i use! I also have a trial of power DVD which runs absolutely fine! ahhh! I just cannot get it to playback smoothly! Is this just an inferior set of codecs or is there some fine point I'm missing?? Any advice gratefuly recieved!
  2. laurel
    laurel
    Did it work with the Geforce 2 ok? If so then I'd suggest the ageing 8mb card is the problem.
    Laurel
