Direct connection or through av receiver
Discussion in 'Cables & Switches' started by bikes_monkey, Aug 22, 2005.
  1. bikes_monkey
    bikes_monkey
    Should i connect my DVD/SKY video out direct to my 2 rgb scarts or through my amp? What benefits are there of direct connections and via amp?
    bikes_monkey
  2. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    Well a direct connection will look better. But going through the Receiver will provide On Screen Display - if your receiver has this, many do not, and it may simplify switching as you may need to only switch the reciever, not the TV as well. Really depends on your setup. Do remember that Receivers, will not change the format of your picture so Composite, SVideo, Component and RGB will all remain separate. and you may still need to switch source if your DVD,STB do not output the same. In fact if you are trying to use the best quality output, its almost inevitable that they will not. If you gothe direct connection route, you can always use a more spohisticated remote to switch your TV/display and Receiever at the same time. Some Receivers come with such remotes.
    Rajiv
    Rajiv
  3. bikes_monkey
    bikes_monkey
    Cheers Rajiv
    Probably go scart rgb straight to tv as it doesn't have a component in, also do the same with sky+
    My receiver is a denon 1905 which is probably higher spec than the tv and can't benefit from component.
  4. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,905
    The more links in the chain, the more chance of signal degradation so a direct connection is always best where possible.
