Hi there ,
I’m new to this forum and also just purchased the Arcam AV40 hoping to upgrade to HDMI 2.1 very soon. So far so good in understanding how it works but I’ve now got a problem trying to run Dirac . I purchased the additional licence for the bass software as I have two subs . It’s essentially a 5.2 system .
I can’t get the software to produce the pink noise test tones for level testIng at all . The Av40 has the latest software and I‘m using the umik-1 microphone with the appropriate files .
I have tried the following so far:
1) Tried running software with a connected input source . No pink noise at all no matter what master level is set.
2) With an input set with music playing through the speakers , I ran the software . music is now playing at the master level and the sound level can be changed within the software but no pink noise. This method seems unstable with the software randomly muting the music.
3) Disconnected all source input and output connections to the AV40 . Now I can hear just ticking sounds coming from each speaker and sub . The ticking level can be adjusted by the master level in the software . Still no pink noise . In the right direction ….
im using a laptop with windows 10. Also the microphone has a USB extension lead connected to the laptop.
I’m hoping someone has come across a similar situation and the solution .
Cheers .
Cheers .
