Dipoles on ceiling
Discussion in 'Home Cinema Speakers' started by sapkan, Dec 27, 2004.
  1. sapkan
    sapkan
    Jul 8, 2004
    492
    +3
    My rear speakers need to be ceiling mounted. I am currently looking at some MA and Mission packs that feature dipole rears. I am wondering whether these can be mounted on the ceiling behind the listener with good results? Pls advice
    p.s. dont let me go for bose again :lease:
  2. pacemaker
    pacemaker
    Aug 31, 2003
    546
    +17
    whilst researching inwall speakers came across alot of in ceiling ones!
    given them a thought?
    easier to mount just cut a hole, normall rears would require a complicated mount
  3. PepperDogs
    PepperDogs
    Ever considered Mirage Omnistats?
    In dilemma myself currently looking for rear wall mounted speakers.
    Omnistats, MS Genie, 902 Dipoles currently being considered.
    :suicide:
  4. sapkan
    sapkan
    Jul 8, 2004
    492
    +3
    pace, cant cut ceiling as it is concrete, that is why I wanna know how dipoles/bipoles would sound when ceiling mounted
    pepper, I am looking for a full-sized package with smaller rears (bi/di) because the room is quite big at 7mx4m and I dont think that sub/sat apart from something like bose (dont like it that much) would do the bizz
  5. avanzato
    avanzato
    Jan 21, 2003
    1,878
    Norfolk
    +60
    They can be used on the ceiling but the usual rule applies for dipoles, they should be in line with the seating position. Obviously they must be securely mounted too. I was going to ceiling mount my Jamo THX rears but they weigh several kilos each and only came with tiny brakets for the job.
  6. sapkan
    sapkan
    Jul 8, 2004
    492
    +3
    what is the difference between bi/dipoles?
  7. rookie_wookie
    rookie_wookie
    FWIW, here's my understanding of dipoles/bipoles:
    Monopoles : Fires sound in a single direction
    Dipoles : These speakers fire in the front and in another direction, so that the sound is vague and has no particular direction. Used for surround sound effects
    bipoles : fire sound from both the front and back of the speakers..I think this has an effect of making the sound come froma greater distance than just the distance of the listener from the speakers.
    Any corrections ?
    Wookie
  8. avanzato
    avanzato
    Jan 21, 2003
    1,878
    Norfolk
    +60
    In a dipole the drivers are out of phase, so when the front drivers move outwards the rear drivers move in. This means that there is an area about half way between them where the sound waves largely cancel each other out (the Null). For surround speakers if you sit in this area you hear mostly reflected sound from the room and the speakers tend to disappear so you get a spacious soundfield. Dipole surrounds should have the null not the drivers pointing at the listening seat or they won't work properly.
    A bipole speaker has both the front and rear drivers moving in or out at the same time. These again spread the sound around the room but don't have the null or cancellation area that dipoles do, so have a more direct soundfield.
    There are many variations on the two themes and several speakers like the Monitor Audios can be switched between the different modes.
  9. MikeRJ
    MikeRJ
    Oct 21, 2004
    226
    Plymouth
    Would a dipolar design be a good choice for the side speakers in a 7.1 system ?
  10. sapkan
    sapkan
    Jul 8, 2004
    492
    +3
    guys, can I put either on my ceiling and get good results. thinking of the MA Silver S6 AV in particular
  11. avanzato
    avanzato
    Jan 21, 2003
    1,878
    Norfolk
    +60
    I prefer dipoles for the side speakers and THX still spec dipoles for the side, though some people don't like using dipoles at all. So now it is common for the side speakers to be switchable between two or more modes to cater for all tastes. The Jamos I use have dipole tweeter and mid but a direct firing bass driver that gives a diffuse sound but with bass too.
    Yes you can. The MA silver Fx can have the tweeters wired as bipole or dipole by changing the wiring on the back. Try each option before mounting them and see which you like best.
