Question Dipoles, bipoles or monopoles?
Discussion in 'Home Cinema Buying & Building' started by PoisonJam, Jun 13, 2015.
  1. PoisonJam
    PoisonJam
    Jul 11, 2005
    1,937
    3
    Central Scotland
    +153
    What's the best solution for surrounds in my new place? There's little distance between my viewing couch and rear wall so surround effects sound too directional, rather than ambient.
    The rears are on 100cm stands to add some height. I thought of wall mounting and aiming downwards, also looking much neater, but feel like they'd be too heavy for this?
    Things improved significantly when I pointed them straight ahead instead of towed in. I considered bouncing the sound off the rear wall, but that's an aesthetic compromise too far.
    Would dipoles or bipoles on the side wall work better? Or perhaps smaller satellite speakers mounted high up on the rear wall? With the latter I could also do 7.1 with two on the side walls.
    [​IMG]
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,918
    The Borders
    +3,569
    Try pulling them forward and aimed across the listening position or pointing them at the side wall and let the sound reflect back into the listening position.
    Surround Spks go to the side of the listening position - rears are added in once you go to 7.1.
    Raising the Surrounds above head height and to the side of the listening position is what you are aiming for - 5.1 Speaker Setup Guide
    Joe
  3. Roohster
    Roohster
    Jul 1, 2004
    4,708
    7
    Derbyshire
    +5,797
    If you're still not happy when you've tried Joe's suggestion, dipoles are definitely worth trying.
    I've got a similar setup where Im sat close-ish to the speakers due to room size, and found dipoles helped "de-localise" things.
  4. PoisonJam
    PoisonJam
    Jul 11, 2005
    1,937
    3
    Central Scotland
    +153
    Will give placing them to the side a try, but I'm not hopeful as they'll be even closer there. Seeing the backs of speakers and cables when you walk into the room isn't really a solution I'm willing to go for :)
    I have been considering upgrading anyhow so I'm open to switching away from monopoles :smashin:
  5. Roohster
    Roohster
    Jul 1, 2004
    4,708
    7
    Derbyshire
    +5,797
    I've tried all sorts, monopoles, dipoles, bipoles... currently using (and very happy with) a pair of Miller Kreisel K4 tripoles.
  6. Yorks68
    Yorks68
    May 12, 2013
    40
    11
    East Yorkshire
    +4
    I have Kef dipoles on the side walls and they are fab, would recommend to anyone.
