dipole surround speakers/centre
Discussion in 'Home Cinema Speakers' started by fatrich, Jun 21, 2001.
  1. fatrich
    fatrich
    Jun 21, 2001
    2,579
    71
    halifax
    +36
    can anyone please help me,
    Kit: acoustic energy 109 (front)
    acoustic energy centre
    acoustic energy aegis one (rear)
    Pioneer vsa-e07 (thx ultra amp)
    My problem is i would like to change the rears for a pair of b&w ds6 can anyone tell me if they should be side wall mounted or rear wall mounted? and also i am thinking of changing my centre for a better speaker maybe the b&w lcr6 the only problem is i do like my front ae109's and don't really want to change them just yet.Will voice matching be a problem if i mix the 109's with the lcr6? or can anyone suggest a better mix of centre and rears that will match the front 109's.
    thankyou
    fatrich
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    The best match for the center would be another AE109. :D
    But seriously: matching different brands is not advisable, so you may consider changing the fronts sooner or later, too.
    As for the DS6 (again and again ...): they are limited in the upper frequency (up to 8kHz only) and are therefore IMHO not suitable for DD/DTS or multi-channel music.
    Which doesn't mean they are bad, but rather 'technically limited' ... though in the end it's your call.
