Dipole rears which ones please.
Discussion in 'Home Cinema Speakers' started by abnett26247, Jan 14, 2005.
  1. abnett26247
    abnett26247
    Jan 2, 2005
    227
    16
    I Have asked but no replies! what speakers to use on the back, I have Tannoy floor standers R 2 s and matching centre on the front, Receiver is on its way marantz 7400, I listen to music as much as films 50% so if its dipoles ?what ones please good with both music and films, Dont know much ref dipole radiating type exept i see ther made by Eltax .Mission . Monitor audio. any others and what would be best with the floor standers at the front. The front speakers are 6 ohms but i take it the marantz can handle the 6 ohm speakers( very good amps inside kas says,) thankyou need advice so i can go buy. (Abnett) :lease:
  2. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    audition and see which ones you like the best, but why not just get some tannoys to complete the set. For music monopoles are considered better.
  3. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,191
    2
    +3,664
    Do you have a budget?- I am happy to recommend the MS 506 THX dipole but you won't get much change from £500.
  4. abnett26247
    abnett26247
    Jan 2, 2005
    227
    16
    I m having 2two sorts of opinions on this which is the best overall ie if its 50% each music /films your saying get ordinary speakers not dipole? if i go 7/1 later could i use 2 ordinary and two dipole is that an option . or a no no? thanks /any one else.
  5. abnett26247
    abnett26247
    Jan 2, 2005
    227
    16
    THANKS THATS A BIT TOO EXPENSIVE I THINK ROOM ANY OTHERS?£250 max.
  6. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    To be honest i'm not sure, i've only got 5.1 and i'm not sure id much is gained by going to 7.1, haven't really asked as i'm quite content.
    It is sugested that mono are better for music as it is alot more directional and di/bi are better for movies becuase you get ambient sounds rather than direction on films. In all honesty i got some mission di poles because they looked good (look like the stuff in cinema's) and had decent reviews.
    Are you going for surround music? if not then get di/bi poles otherwise just get some tannoys that match your current set, if in doubt audion if you can. Try equivently priced di/bi and monopoles and see which one you like the best.
  7. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    I am using the MS506 THX Dipoles and they work fantastically well with the SR7400, great speakers!
    Do Tannoy not do Dipole rears? Monopoles will be better than a small di/bipole for music though in my opinion. Larger bi/dipoles maybe different, but I can't be certain.
    These might work for you: http://www.avland.co.uk/jbl/e10/e10.htm and they are within budget.
  8. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    They are nice looking speaker!
  9. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Second that :D
    What I have heard is that for a 7.1 setup the best options are bipoles in the sides with mono poles in the rear. IM looking for a cheap(ish) pair of mono poles (maybe the baby evos) to try it out and see. Bipoles are not the best for multi-channel music. I know.
  10. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    those JBL's
    "Maximum Recommended Amplifier Power 10W"
    is that a typo?
  11. russraff
    russraff
    Aug 1, 2000
    2,415
    Newcastle
    +64
    Yeah, that's a typo. Go here for the manufacturers site.
    Russell
  12. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    I think I might get those JBL's to replace the Elacs I'm currently using for SBL and SBR.
  13. dazca1
    dazca1
    Nov 2, 2003
    556
    +8
    Ive just bought some Energy Cr3 surrounds from the nice guys at Sevenoaks Newcastle, they are di-pole and bi-pole. Nice reviews.
    Got them for a really good price :D bargains much cheapness :thumbsup:
    Try your local Sevenoaks see if they have any.
