M
MrSafety
I have one of these infrared dimmers
http://www.tlc-direct.co.uk/Products/VLIQ1402.html
and have been using it for quite a while. Before Xmas I installed 2 sets of Ikea low-voltage lights
http://www.ikea.co.uk/webapp/wcs/st...uctId=15174&langId=-20&parentCats=10111*10448
and put 4 x 20w bulbs on each transformer. So, this gives me
gang1 - operates a single 60w bulb in a walk-in cupboatd
gang2 - operates 2 ikea transformers powering 4 x 20w bulbs each - a total of 160w.
The dimmer switch ran warm (but the dimmer switch instructions said it was normal so don't worry) and the switch buzzed when the lights were on or dim which was annoying but I lived with it.
Anyway, on Friday night while the lights were about half-dimmed for 10 minutes continuously, something went "crack", the lights were jacked up to full brightness and the dimmer control wouldn't turn the lights off. It also smelt of electrical burning so I turned off the circuit and took the switch off the wall.
The following day I refitted the switch to the wall but the other way around - I figured I had blown gang 2 but gang 1 was still working and only operating a walk-in cupboard so I swapped them over. The minute I turned on the power the wall switch started smoking and I ran downstairs and turned off the power.
I appear to have blown both gangs on the lightswitch and have reverted back to the normal (undimming) lightswitch.
So, did I overload the switch? It had worked for 1 month - was I lucky or was the switch dodgy?
If I am overloading it, can anyone recommend a suitable 2 gang replacement for my lights which won't cost the earth? Or do I just need to have, say, 3 bulbs on each light instead of 4?
[I assume it is clear from my predicament that I am not living up to my nom de plume when it comes to electricity :- !]
