Dimensions of stand on Sony KE32TS2 plasma
Discussion in 'Home Cinema Buying & Building' started by APC, Jul 11, 2004.
  1. APC
    APC
    Hello,
    I'm thinking of taking the plunge at last with the Sony KE32TS2, but I was wondering what the dimensions of the stand are? This is the tabletop stand that comes with it, not the optional AV stand?
    I'm guessing that it's around 60cm, because the unit is 86cm overall, but maybe I'm wrong. If any KE32TS2 owners could grab a tape measure I'd be most grateful!
  2. Rob20
    Rob20
    Jul 3, 2004
    3,222
    +740
    also I'd be interested to know if the component input is prog scan compatible. and what types. :)
