Dimensions of Panny5/6 + bracket
Discussion in 'Home Cinema Buying & Building' started by nobbydog, Jul 13, 2003.
  1. nobbydog
    nobbydog
    Jun 19, 2003
    262
    Comfy basket in the utility room
    Question for all owners of Panny 5's with wall brackets - If you were to measure the dimension from the wall (to which the bracket is fixed) to the front edge of the display, what do you get? If it is more than, say, 4 or 5 inches I may look into the possibility of cutting out the plasterboard and fixing the bracket into the recess. Has anyone done this?
  2. loonatic
    loonatic
    Jan 4, 2003
    1,877
    41
    Springwell Village, Gateshead
    +16
    If you do inset the panel into the wall will you not have issues with airflow and possible overheating of the panel ?
    Cheers, Lee
  3. Merritt
    Merritt
    Feb 5, 2003
    262
    Hampshire
    ok -
    from the wall to the back of my panny5 is 2.5"
    from the wall to front edge of display is 5.5" approx
    however, I agree with loonatic - it gets very warm behind the panel and I think you'd be asking for trouble.
    Steve
