Dimensions of 42" and 50" pannel
Discussion in 'Plasma TVs Forum' started by playedalive, Jan 21, 2008.
  1. playedalive
    playedalive
    Jan 20, 2008
    62
    Cheltenham
    I am in the middle of deciding between the 42" or 50" model of the 1080p panasonics. I am trying to figure out if the screen will be too big for the room.
    Does anyone have the actual dimensions of the width and height of the pannels and not the tv including the bezel, speakers ect.
    How much of a difference will it be by going from 42 to 50? I sit about 6-7 ft away from the screen.
  2. un1eash
    un1eash
    Nov 14, 2007
    5,003
    2
    +1,421
    Depends which model of 1080p panasonic your referring too. I'll assume you mean the PZ70 models....
    42PZ70 - 1,134 mm × 641 mm × 116 mm - 35.0 kg
    50PZ70 - 1,323 mm × 754 mm × 99.5 mm - 43.0 kg
  3. Andy98765
    Andy98765
    Feb 15, 2006
    10,472
    2
    +1,365
    At 6-7 ft away I would suggest a 42" is enough.
  4. playedalive
    playedalive
    Jan 20, 2008
    62
    Cheltenham
    those are the total sizes of the screen. Im wondering what the size of the pannel is i.e just the screen and not the parts that go around it. It shouldent be specific to panasonic but any screen in general.
    thanks
  5. un1eash
    un1eash
    Nov 14, 2007
    5,003
    2
    +1,421
    Well that would be 42" and 50" diagonal.
    If you cant do the maths thats roughly, given that the screen is a 16:9 ratio.
    42" is 36.5"x20.5" give or take an inch
    50" is 43.6"x24.5" give or take an inch
  6. playedalive
    playedalive
    Jan 20, 2008
    62
    Cheltenham
    thats exactly what i was looking for:thumbsup:
