Dimage 7i v Nikon D70
Discussion in 'Photography Forums' started by martynk, Jul 25, 2004.
  1. martynk
    martynk
    I'm currently using the Dimage 7i. Very pleased with it generally, but too much barrel distortion at 28mm equivalent on architectural subjects with strong vertical and horizontal planes. This is a real problem , for various reasons.
    Thinking about a D70. I know this is in a different class, and before I spend the money I'd like to askif anyone can comment on the visible distortion at the wide angle setting for the 18 - 70 kit lens, and can the older, manual, Nikkors work with the D70 body at all?
    Thanks all
  2. matiano
    matiano
    As a rule of thumb the D70 is compatible with all old AF lenses, the mF ones dont generally work, i think its something to do with the sensor used. The distortion should not be as noticeable on an 18mm simply due to the fact that the magnification is x by 1.6 so you are really looking at a 27mm at the lowest end.
    Hope that made some sense!?
