Diiferent programmes from 1 sky dish
Discussion in 'Sky Digital TV Forum' started by raigraphixs, Oct 18, 2001.
  1. raigraphixs
    raigraphixs
    Jul 11, 2001
    60,450
    +22,082
    HI,
    Now sky are offering the service of allowing different programes to be viewed in different room using the same dish;
    1. How is that done, do they put a new LNB on the dish?,
    2. Can we get that serivce without subscription, as i already have a sub, and only want a box for free2air programmes?
    3. Can i get a independant installer to do the job, if sky decline?
    thanks
    rai
  2. Filmbuff
    Filmbuff
    This has been covered loads so it might be worth reading through some of the earlier posts but basicly
    1)yes
    2)yes (send off to the bbc for a card)
    3)yes
