DigiTV Network setup
Discussion in 'Desktop & Laptop Computers Forum' started by Digger, Jan 15, 2005.
  1. Digger
    Digger
    Dec 31, 2003
    4,204
    World Wide Supermarket
    +206
    I am having some trouble getting my Nebula Digitv client to see the server, and vice-versa (obviously). Everything is setup as i believe it should be. client is a wireless laptop, and all running through a Netgear wireless router with port forwarding enabled. File-sharing / ping etc works just fine. I tried multicasting option too. I have turned off XP firewall too.
    I cannot even specify the Digitv Server's IP address as the option is grayed out as the software looks for it automatically. If i could just get in there and change it I am sure it would work.
    cheers
    Dave
  2. Gazebo2
    Gazebo2
    All I can suggest is:
    - set the multicasting option on server - turn off.
    - set the client to be a client and select multicast and turn off.
    - turn on server
    - turn on client - if server is not found then set the network options to client and multicasting again.
    If this doesn't work, check the versions of the software - the only problem I had recently was when my server sneakily updated itself to a new version of the software which was incompatible with the old version on the client.
  3. Digger
    Digger
    Dec 31, 2003
    4,204
    +206
    Ok...thanks for the reply Gazebo...got it working finally...but no video...dont think my laptop's 3 yr old Intel 82830M graphics chipset is up to the task.
    I will check with Nebula next week though...I might still be missing a trick here...
