Digitizing on a JVC GR-DV700
Boogie Badman
Has anyone tried to feed an analog signal into the camcorder to digitize it?
The manual says you can do it but when I follow the instructions, it doesn't!
Any ideas?
V
virgola
It *should* do it ! It can also act as an A/D converter (without recording the tape). For this purpose it must be in VCR mode and without tape inside.
Boogie Badman
Figured it out, the scart block I was using (supplied by JVC) is not bidirectional - I'm off to Maplin to get some adapters.
dqtvsound
Just had to jump through hoops to record into the analogue inputs of the DV700. I tried 2 different VCR's and ended up having to buy a new Panasonic VHS deck. Worth my while, because I've loads to do. The camera seems to be quite particular about the stability of the video output from the VHS. Results digitised straight through to PC via firewire and burnt to DVD very good so far, although time consuming.
good luck ;)
65-inch LG C1 Review coming soon to AVForums
