Digitheatre help please
Discussion in 'AV Receivers & Amplifiers' started by Mikeb_78, Sep 2, 2001.
  1. Mikeb_78
    Mikeb_78
    I've got the digitheatre 5.1 connected to my samsung 709 via the coax digital lead and I get the sound cutting out ever few seconds for very short periods of time. Almost like someone is constanly hitting the mute/unmute button VERY fast.
    This happened today when I first turned the player on, and also happens when I press stop on the player and then press the test button the DD remote, I can hear the same problem though the white noise.
    However, I DID watch an hour of Bugs Life on it this afternoon with no problems and then this evening I watched 30 mins of Face/Off before the problem re-occured.
    I then connected the PS2 via an Optical lead and all was fine.
    Is it likely the the DD system is at fault? Possibly the coax input? Or more probable that the DVD player has a fault?
    Any suggestions welcomed...
