Digitheatre DTS & Tosh 210E
Discussion in 'Home Cinema Speakers' started by hobbes, Aug 31, 2001.
  1. hobbes
    hobbes
    I was wondering if this system would do me. I only have a smallish room and so massive speakers aren't really needed. The Digitheatre DTS has got some really good reviews.
    Anyone had experience with either of the above? Also, will i need extra seperates? The DTS has built in decoder and amp. I'm not very sure about receivers, will one be needed?
  2. js
    js
    Its all to do with budget to be honest. I've not heard the Digitheatre but i've read many reviews that say its good both in terms of its cost and size.<br />Hopefully someone here has heard it and can offer some advice.<br />How much can you afford by the way?
