Digital Video Essentials - how to go about it
Discussion in 'LCD & LED LCD TVs' started by s3marc, Aug 24, 2005.
  1. s3marc
    s3marc
    May 10, 2005
    134
    +5
    I have ordered the DVE dvd and was wondering if anyone has any pointers or observations on how to use it in combination with an LCD tv (what tests to ignore for instance). And any advice with regard a Loewe Xelos and calibrating it.
    TIA
    Marc
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,684
    Galactica C.I.C.
    +214
    Best advice I can give, is put in in the DVD player and watch it all the way through.
    You can choose between basic calibration and advanced , plus audio calibration. Watch it and it will tell you what to do and when as you go through it. :)
  3. multiply
    multiply
    Sep 7, 2004
    312
    Surrey
    +9
  4. s3marc
    s3marc
    May 10, 2005
    134
    +5
    it is the colour/brightness and contrast which are most intesting to me.
    The loewe, and i presume most other LCD tvs, can adjust green/red/blue separately and there are various other settings that can be adjusted. i dont know what some of them even mean - i will probably be posting some questions on this later. i intent to write down the initial values so that they are not lost.
    The only thing I had to say at present is that this disk will only give the correct settings for the dvd - the sky+ box has completely different input levels , do sky have any channels with 'test cards' on them, to allow some sort of calibration.
