digital uses D/A converter?
Discussion in 'Blu-ray & DVD Players & Recorders' started by steroid, Jan 31, 2002.
  1. steroid
    steroid
    I think it does sound like a dumbass question :rolleyes: , but does the optical out make use of the D/A convertor in the DVD player?
    Cause the pioneer 440 is said to use a fab D/A convertor but I will be connecting via optic to my Yamaha Rxv-620. I want to know if this factor (D/A convertor) should influence my decision.....
    Sharan
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Nope a D/A converter (DAC) would convert from digital to analog, but since the optical out carries a digital signal there is no conversion in the player.
    Well, except from electrical to light.
    The conversion from digital to analog will then take place in the amp.
  3. steroid
    steroid
