elliot_01
Hi Readers,
Can I ask what I fear is likely an embarassingly newbie question!?
I may need to buy a digital TV tuner, and would like to know if they are also backwards compatible with analogue (for instance, if I found, after buying one, that I had to replace/upgrade my aerial - I'd be stuck with no signal at all).
After reading some of the product information, for instance, the Panasonic TU CT30 Digital Terrestrial Tuner, it's not obvious whether they do support analogue too, or not.
