Digital stream dhr8205u stuck on loading
Discussion in 'Digital TV & Video Players & Recorders' started by worsleyman, Mar 22, 2015.
Tags:
  1. worsleyman
    worsleyman
    Nov 2, 2011
    16
    4
    Hi all can anyone help me, turned on box this morning and it's stuck on loading lights are flashing can't do a thing with it turned off and on pressed remote control nothing what's wrong with it can anyone sort this out for me please.
  2. JayCee
    JayCee
    Jan 20, 2004
    23,226
    Lanarkshire
    +2,486
    Have you tried a power cycle as in unplugging it, wait a few mins then plug it back in?
  3. worsleyman
    worsleyman
    Nov 2, 2011
    16
    4
    Hi yeh tried that didn't work at all?? Thanks tho
  4. Katyme
    Katyme
    Mar 26, 2015
    4
    Hartlepool
    Mine does exactly the same so I have to switch it off at the back off switch then wait 5 sec's and switch back on. The machine closes down and has to be switched on re the hand set. It works for me tho I'm sure I shouldn't have to do this if it was working properly. Hope this works for you. I would take it to be repaired but I'm disabled and could never carry it.
  5. petrev
    petrev
    Jul 4, 2007
    4,345
    TX Mendip - DHR8205: FW4.22 - M1.35Blk
    +1,015
    If the good old Power-Cycle doesn't work then you could try a Full reinstall of the Firmware.
    Someone else just had the same issue and you can read about it in the main thread.
    You have to download an MSU FW package (8 files) from the Wiki and extract to root of a FAT32 USB stick (not all work so you have to keep trying different sticks sometimes).
    Software Versions - DigitalStream DHR Wiki
    You have to use the Full Version (Rear USB Boot) Method to Update.
    How To - DigitalStream DHR Wiki
    Details in the Wiki
  6. AlanJ75
    AlanJ75
    Jul 27, 2015
    Scotland
    Did anyone solve this problem?
  7. IanS
    IanS
    Aug 10, 2005
    1,082
    2
    63
    South of Birmingham
    +217
    Well, I had the "Loading" issue this morning. Powering off via the rear switch did not help, but the MSU 8-file rear update worked for me. :)
  8. blissbody
    blissbody
    Oct 7, 2010
    111
    +14
    Ditto, also mentioned in another thread.
    Graham
  9. alex blackburn
    alex blackburn
    Oct 3, 2012
    5
    My problem is I replaced the HDD to resolve loading, loss of vision and audio and being unable to access recorded programmes. It appeared to work as it restored vision and audio but it is still taking 5 mins to load and it won't record. I have tried 5 fat32 usb's to reload the software, one which had been used previously to successfully update the software, but it won't recognise any of them. The pvr is now 7 years old, is it time to bin it or can something be done to restore full functionality?
  10. Ensor
    Ensor
    Nov 9, 2017
    492
    46
    Birmingham
    +147
