Digital SPL meter from maplins
Discussion in 'Home Cinema Speakers' started by Jeff, Jan 9, 2001.
  1. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    I was just about to order the digital SPL meter on maplins web site, when I noticed on the spec sheet that the frequency range starts at 300HZ. Isn't that a problem? especially when calibrating the subwoofer?
  2. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Anyone?, I know from a while back that a few of you baught one.
  3. General Skanky
    General Skanky
    Jul 28, 2000
    4,247
    71
    +43
    I would have thought it's no good as you need to get down to 20 Hz, as you rightly say.
    Douch!!......Wot's da madder, da CIA got you pushing too many penzils?
    Work: www.hughes-tv.co.uk
  4. shabbyroad
    shabbyroad
    the only input I'd have is that there's no point in the meter going down that low if the microphone you're using cannot accurately pick up those low frequencies (similarly for the higher frequencies).
    visit Shabbyroad Records, Dublin, Ireland http://www.shabbyroad.com
