Digital Radio question: Pure DRX-702ES
Discussion in 'Hi-Fi Stereo Systems & Separates' started by rimibar, Jan 4, 2005.
  1. rimibar
    rimibar
    May 17, 2003
    427
    Cambridge
    +4
    I have a 702ES digital radio currently connected to my AX10i via a decent quality optical cable. I am wondering whether I can "warm-up/deepen" the sound at all by using its phono connections?
    Has anyone any experience of doing this? Is better to keep the optical connections?
    Thanks!
  2. rimibar
    rimibar
    May 17, 2003
    427
    Cambridge
    +4
    Any response would be great!
  3. rimibar
    rimibar
    May 17, 2003
    427
    Cambridge
    +4
    Hi just posting a response in the hope that this post gets read more - and hopefully responded to! Any opinions would be great (preferably related ones!!!!)
  4. SamirP
    SamirP
    Apr 28, 2003
    1,232
    South Of The River
    +32
    Hi rimibar
    I would say just try it via analog and see if you hear any improvments, or one other option could be to try adding external DAC
  5. rimibar
    rimibar
    May 17, 2003
    427
    Cambridge
    +4
    Thanks Samir - that is my project for the weekend! Was hoping that someone might have experience in using this specific unit, hence the post.... Ah well....
  6. warrj
    warrj
    First let me say that I have no direct experience of your radio. However AIUI the DAC/output stage of your particular model has been tailored to minimise the thin digital sound which DAB tends to produce. Therefore you'd almost certainly 'warm-up' the sound by using the analogue outputs from the tuner.
    Regards,
    Jules.
  7. rimibar
    rimibar
    May 17, 2003
    427
    Cambridge
    +4
    Thanks for this Jules. Will give it a whirl!
