Digital Radio on Sky+
Discussion in 'Sky Digital TV Forum' started by Ash007, Jun 6, 2004.
  1. Ash007
    Ash007
    Dec 29, 2001
    217
    16
    Rochdale
    Some of my local FM radio stations also apparently output DAB (Digital Radio) e.g BBC GMR (Greater Manchester Radio).
    Does this mean I should be able to get them on my Sky+ digibox? or is DAB different to the digital radio stations on Sky.
    put another way
    do u need a DAB radio if i've got Sky+?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    There is no technical reason a local FM station can not broadcast on DAB and/or Dsat, however there are cost factors and some sporting rights which are better suited to the more localised DAB platform as opposed to the nationwide dsat delivery system.
    DAB is a digital terrestrial platform for distributing radio, it has no direct connection with digital satellite distribution.
    It's exactly the same as distributing television on DTT and Dsat, some channels will be on both platforms and some will be on one or the other, it's all upto the broadcasters and how they choose to distribute their product.
    DAB on the whole is inferior (audio wise) to digital radio on both Dsat and DTT however you will probably find more local stations on DAB so the question you have to ask is which platform provides the widest range of channels you like and of course you can listen to DAB while another member of the household watches SKY.
