Digital player without a PC?
Discussion in 'Headphones, Earphones & Portable Music' started by Artie Fufkin, Feb 12, 2005.
  1. Artie Fufkin
    Artie Fufkin
    Aug 11, 2004
    1,607
    Aberdeenshire
    +181
    I'm thinking of buying a portable player as a present for a friend who doesn't have a PC and I'd rather ask you for help then go to Dix0ns.
    I believe that there are some models which will record directly from a hi-fi system - is this right? Are they any good? Ease of use would be a priority. Or should I forget the idea and choose a different gift?
    Thanks.
  2. Marvt
    Marvt
    My iriver HP140 has that function though its a 40gb one and fairly pricey.
    Not sure of any smaller/cheaper players though
  3. Artie Fufkin
    Artie Fufkin
    Aug 11, 2004
    1,607
    Aberdeenshire
    +181
    Thanks Marvt. I take it these machines convert to MP3 as they are doing the recording (from a line source). Or do they just fill up the drive with uncompressed music?
    I've seen a Packard Bell Audio Dream 1GB on the Curry's site - reduced from £229 to £129. This accepts a straight hi-fi connection and seems to be what I am looking for.
    But does anyone have anything, good or bad, to say about it before I buy?
  4. Artie Fufkin
    Artie Fufkin
    Aug 11, 2004
    1,607
    Aberdeenshire
    +181
    Anyone got a comment? Please. Time is running out.
  5. inventor
    inventor
    Nov 29, 2004
    33
    Yes, the iriver can certainly convert to MP3 on the fly.
  6. clarkyb
    clarkyb
    Feb 2, 2005
    266
    28
    +58
    my opinion would be to get a minidisc player of ebay, a really nice one will only cost you £60 and if you get one without net md (ability to connect to a pc) THEY WILL BE EVEN CHEAPER
    and they record off optical cable from your hi fi
    lot cheaper than the IRIVER :smashin:
