Digital Output
Discussion in 'Blu-ray & DVD Players & Recorders' started by G8PCW, Jan 12, 2004.
  1. G8PCW
    G8PCW
    I have what I think is a fairly straightforward question - but I'd like some advice anyway!
    I am in the market for an AV Amp which will include DTS and Dolby Digital decoders. I plan to connect it to a DVD player through a co-axial digital cable. Am I right in thinking that, as far as sound goes, it's irrelevent how much I spend on a DVD player since they will all simply stream the digital audio data down the cable to the Amp which then has to do the hard work of decoding the digital data and doing something with it?
    Thanks for your help.
    Pete
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,788
    Somewhere in South Yorkshire
    +4,975
    Has it ocurred to you that you may want to obtain the best Picture Quality, too? Here, the work is always all done in the player.
    Plus there are issues of transport stability (and 'jitter') that can theoretically affect the quality of the audio bitstream regardless of where it is decoded.
    It's probably also true that a really good quality player will be more tolerant of errant discs than a poorer one is. I know this is the case with my (ageing, now) Pioneer 737.
  3. kelvin
    kelvin
    Apr 22, 2002
    1,544
    Down South... (Bournemouth)
    +45
    Just noticed this thread...
    To be honest, yes, you're pretty much right (save the arguments that nigel has mentioned above) - the main difference as you "move up" tends to be in the area of picture quality rather than sound.
    Analogue outputs are a different story, but if you only ever intend to use the digital out then I sincerely doubt that you'll notice a huge difference between a £100 player and a £1000 player (IMO anyway - I'm sure there will always be people who "can" ;))
    Hope this is of some use to you... good luck!
    K.
  4. G8PCW
    G8PCW
    Nigel/Kelvin,
    Thanks very much for your responses. You've confirmed what I thought to be the case - which is exactly what the salesman at Sevenoaks Hi-Hi didn't do when he told me that I'd notice a significant increase in "height, width and depth" of the sound!
    Regards,
    Pete
  5. Brogan
    Brogan
    Oct 9, 2003
    7,476
    Cary, North Carolina
    +481
    LOL - don't you just love these phrases that salesmen come out with...:rotfl:
    What a load of cobblers.
  6. kelvin
    kelvin
    Apr 22, 2002
    1,544
    +45
    No problem :)
    :rolleyes: :rotfl:
    K.
