Digital out for cds?
Discussion in 'Blu-ray & DVD Players & Recorders' started by manz, May 26, 2004.
  1. manz
    manz
    May 26, 2004
    89
    UK London
    +3
    1st post here. :)
    I have a low-end DVD player which I also wish to use for music cds.
    If I used the optical digital outputs to send the signal to a higher-end AV receiver would the receiver do the digital to analogue conversion?
    Thanks.
  2. Underscore
    Underscore
    Welcome!
    Yep. That's what I'm doing at the moment since my CD gave up the ghost. My amp does a lot better at converting to analogue than the DVD player does.
    _
  3. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    Yes..... what good it might do is another matter..... this depends on your opinion of digital..... if bits is bits to you then this is awonderful way to go, if you are like me, then you have additonal parameters to balance.
    ad
