Digital-out cable
Discussion in 'Desktop & Laptop Computers Forum' started by jayjay, Feb 6, 2002.
  1. jayjay
    jayjay
    Jul 18, 2001
    353
    nwsex
    +8
    I've an Audigy souncard with the internal Live drive that I'd like to hook it up to my Sony receiver STRDE835. What kind of digital connection do I need? Can I use any mono 3.5 to single RCA cable??
    Confused as to what kind of data rate is output as well?
    Any recommendations on a cheap speaker package for the set-up.
    Thx in advance JJ
  2. jayjay
    jayjay
    Jul 18, 2001
    353
    nwsex
    +8
    OK got a cable - a cheap coax 3.5mm to RCA - how do I get 5.1 to a DD amp? I've changed the speakers in control panel to 5.1 and am using PowerDVD but no 5.1 output through both the live drive or 3.5mm jack. What am I doing wrong?
    Jay
  3. jayjay
    jayjay
    Jul 18, 2001
    353
    nwsex
    +8
    OK OK excuse my posts.......
    Right, I have a DD signal to the amp but now I have the DVD running too fast? The menu and everything just flash through like they're on double speed...what gives??
    Jay
  4. Robpaul
    Robpaul
    Where did you get your cable from?? I have been looking on the web and havn't had much joy so far.
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Robpaul, any radio bits shop will knock you up a starter cable for £10 or so, for better quality, try www.custom-cable.co.uk They'll make anything to spec.
  6. jayjay
    jayjay
    Jul 18, 2001
    353
    nwsex
    +8
    Rob - mine's a real cheapy, but what's the point when everything's at 2x speed!
    I thought that Chord did one as well, but can't find it on their site. Could have been a 3.5mm to 2xRCA now that I think about it.
    Anyone got an ideas on my problemo?? Software related? PowerDVD maybe?
    Jay
  7. jayjay
    jayjay
    Jul 18, 2001
    353
    nwsex
    +8
    Here's the solution for anyone else interested...
    When I built the PC I installed an SBlive card. With XP I had to download the new drivers for it. When I insatlled a Audigy it was running the XP drivers but not the correct ones. So I un-installed the existing drivers and installed the proper ones - problemo fixed.
    Jay
