digital or analogue sub?
Discussion in 'Subwoofers' started by crackles, Sep 30, 2004.
  1. crackles
    crackles
    Hi all,
    What is the difference between a digital and analogue amp found in active subs?
    Crackles
  2. BK Electronics
    BK Electronics
    Active Member AVForums Sponsor
    Aug 10, 2002
    376
    Essex
    +25
    There are different levels of digital amps, some can accept a digital input then deal with the volume, frequency phase Etc. via a DSP core then feed straight into a digital amp without even using an analogue path. There are others that deal with the frequency, Phase, volume Etc in the analogue domain then feed into a digital amp and then there are the amps that are completely analogue.
    The advantages of a digital amp (Class D) is that it is highly effiecient and does not dissipate to much heat so the amp runs cool, does not need a heat sink.
    The advantage of an analogue amp is the sound quality, although class d amps have made great strides forward some people prefer the old system.
  3. crackles
    crackles
    Marvvelous, thanks for that. I'm not to sure about all the technical stuff, but reading between the lines it looks like either way would be ok then?
    The BK XLS200 is analogue, so I guess thats why it has all those fins on the back then!
    Do you know what the 4 dials are for on the back of this (and other) subs?! Just to confuse novices like me, or is there a purpose?!
    Cheers!
    Crackles
  4. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    As Mr Gleebles makes them I would hazard a guess that he does know what they are for. :D
  5. Xstyle
    Xstyle
    Sep 27, 2004
    3,496
    Berkshire
    +146
    Mr Geebles makes the BK sub, or amp... or just the knobs in general?
    Good question Crackles ... exactly what I would like to know...
  6. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Surely all subwoofers will come with an instruction leaflet telling you the purpose of each dial and socket so I wouldn't worry about such things in advance.
  7. BK Electronics
    BK Electronics
    Aug 10, 2002
    376
    Essex
    +25
    Hi There
    If you email me at tom@bkelec.com I will email back a PDF of the manual, please try email me before tonight as I am not at work next week
    Tom
  8. Pollywoggle
    Pollywoggle
    Aug 14, 2000
    1,449
    South Shropshire
    +80
    Probably on tour with a giant snake :laugh:
  9. Xstyle
    Xstyle
    Sep 27, 2004
    3,496
    Berkshire
    +146
  10. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    it is purely down to how you design your amp, personally I can see NO reason to stick with analogue amps when we are talking subs.m The decision is just a non brainer, in fact there are so many advantages to digital amps
    re sound quality, well I might be persuaded for full range amps but subs working over a tiny bandwidth, no way :lesson:
  11. Beobloke
    Beobloke
    Aug 10, 2004
    1,314
    Out in the Sticks!
    +66
    The Beekeeper is quite right - digital amps do suffer from distortion at higher frequencies, but as the average sub amp doesn't do much at over 200Hz, the advantages of size, power consumption and efficiency far outweigh this.
    Adam.
  12. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    This obviously is dependent on the design of the amp,switching frequencies and output filter design,with some of the newer offerings from e.g. Belcanto,and Tact being very good on that score,along with the TriPath Class T design.
    The point remains true however,that in terms of cheaper Class D designs for use in many subs,distortion will rise at high frequencies,but will not be an issue at the frequencies subs operate at.
