Digital or Analog Coax?
Discussion in 'AV Receivers & Amplifiers' started by BadAss, Jan 4, 2002.
  1. BadAss
    BadAss
    Feb 2, 2001
    2,967
    England
    +182
    At the moment I use a standard coax cable as the digital connection from DVD to Processor but Ive seen a Digital Ixos on sale for £25. Will there be any difference between the two or do they all do the same job?
  2. boogie man
    boogie man
    Dec 4, 2001
    233
    19
    Sunny Berkshire !!
    Hi there badass
    I Myself use cable talk digital coax i got about 2-3 years cost about £80 i think
    IT made a big big difference between the standard cable that came with the dvd:rolleyes:
    sound stage is alot better cleaner note deeper etc.....
    bests bet is to try it & see if you can hear any difference:p
